Enables TCP flag checking.
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default is disabled.
TCP SYN flag==1 and the source port<1024
TCP control flag==0 and the sequence number==0
TCP FIN, URG, and PSH bits are set, and the sequence number==0
TCP SYN and FIN both are set.
This command was first available in ExtremeXOS 12.0.
